S&S quickee rod tubes?
Old 06-29-2013, 09:49 PM
jus2anoyu's Avatar
jus2anoyu
jus2anoyu is offline
Originally Posted by Lowcountry Joe
Glad you figured it out. The S&S quickies are awesome pushrods.
Until you discover that they are rubbing the tubes and making noise.
Old 06-29-2013, 09:52 PM
jus2anoyu's Avatar
jus2anoyu
Originally Posted by JohnSWA
I'm still confused, but I'l figure it out. I wish there was an illustrated parts break down of the tube assembly. That would make this a no brainer! I'm cracking up that the gear cams went in so well, but I'm lost on the rod tube!
The tubes assemble with the upper inside the lower, 1 oring, 1 flat washer, 1 spring, and then the chrome cup that covers all of that. If you find that the clip is an inch too short, you either have an incorrect clip, or you are using an incorrect lower tube.
Old 06-29-2013, 09:54 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
That doesn't happen to everyone though. Just the lucky ones!
Old 06-29-2013, 09:56 PM
jus2anoyu's Avatar
jus2anoyu
Well call me a lucky sob then! There is a link that shows how to open the tubes up with a drill bit and die grinder. I gave up and went with se tapered. No problems since...
Old 06-29-2013, 09:58 PM
Lowcountry Joe
Glad you got the noise problem whipped. I think mine are fine, but I can't hear **** anyway.
Old 06-29-2013, 10:02 PM
jus2anoyu's Avatar
jus2anoyu
Only one of mine was rubbing. Front exhaust, which is typical. That one has the steepest angle. I hated to take them out, they look like good sturdy parts, but I wasn't willing to spend hours hacking up perfectly good pushrod tubes to make them work.
Old 06-29-2013, 10:04 PM
JohnSWA's Avatar
JohnSWA
JohnSWA is offline
I actually didn't figure it out yet as I can't figure out where the o-rings go inside the tube. I'll figure it out eventually or maybe somebody here can help me out as I'm sure somebody remembers how the tube is installed. I hate sounding like an idiot as I'm quite mechanically inclined. I've been an aircraft mechanic for nearly 30 years. I just have to laugh at myself on this one.
Lowcountry Joe
I hear ya. I just installed Gatermans and should have looked at the front exhaust for any rubbing. If it was to be rubbing, is it at the top?
Old 06-29-2013, 10:05 PM
jus2anoyu's Avatar
jus2anoyu
I posted the assembly a few posts above. it all makes sense once you get it apart.
Old 06-29-2013, 10:07 PM
jus2anoyu's Avatar
jus2anoyu
If it's minor, yes, at the top. If it's major, I've seen pics of some that rubbed at the bottom. Drop the tubes down and look for witness marks on the rods. The soft aluminum tubes will 'shine' the machined rods if they are rubbing.
Quick Reply: S&S quickee rod tubes?
