Removing Lower Vent Doors
Old 06-30-2013, 06:06 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,072 Likes on 2,507 Posts
I take my vented lowers off in the summer on my Road King. I keep soft lowers in the bag if it rains. I know a lot of folks say there isn't a difference (i.e. heat on the engine) between lowers on vs. lowers off and frankly I don't have a quantitative answer. I do know this; below about 50mph it gets hot on my legs with lowers on, even with the vents open.
Old 06-30-2013, 06:22 AM
hapbob's Avatar
hapbob
hapbob is offline
Default open
I had lower doors closed and it was hot here (Finally). And decided to open them and Wow did I feel more heat from engine...Figured the extra air to motor was a good thing...not that uncomfortable for me...I'm sure Harley CO has done extensive research on vented lowers and effect on their engine ????
Hap
Old 06-30-2013, 12:38 PM
swervin irv's Avatar
swervin irv
swervin irv is offline
Remove the bolt pivot hardware top and bottom drop it down at an angle,cut a 1/2 inch slot out of the thin top piece above the long slot 1 inch from the inside with sharp side cutters.Then you can remove or install with ease and they will close or open with no problems.
SnoRider
01-30-2020 10:26 AM
Budda109
07-03-2016 12:14 PM
Homeward Bound
09-21-2013 01:54 AM
dondee
17
06-13-2012 06:14 AM
Cheeze
03-27-2009 12:02 PM
Quick Reply: Removing Lower Vent Doors
