Need help!! Cruise issue
I did the below diag procedure and all worked except for the brake steps...I didn't get a green light with either brake pressed. It went back to red and stayed on. For starters it won't even work with the roll-off switch plugged in! Cables are adjusted,but I don't hear the engine rev during the cable lash initialization, but the lights work correctly. I need help!!
Ignition off
switch cruise ON
Hold cruise SET to SET position and switch ignition ON
Green light should come on.
Hold cruise RESUME to RESUME and green light should come on
Release RESUME and hit FRONT Brake, green light should come on
Hit Rear Brake and HOLD for 5 sec, green light should come on
Ignition off
switch cruise ON
harleybob815
16
12-31-2022 12:35 PM
