What Air Cleaner Would You Put On
Greetings All,
I just sold my 08 Street Glide and purchased the 09 green monster. I'm not sure if the picture attachment is going to work. I wanted to see what air cleaner you would put on? I'm leaning towards the SE chrome chisel number 29400104 or the PM Max HP in chrome. What would you use?
Thanks in advance
-sunnenman
Thanks in advance
-sunnenman
I just learned something recently. The Arlen Ness stage 2 air back plate has the breather holes cast into the back plate and any oil seeps out the front and the venturi action controls the oil intake much better, instead of the rubber tubes that just flood the intake with oil. Probably not an issue for most folks but it sounds good. Any cover/filter can be used.
I have the RC Components Majestic Eclipse air cleaner on mine. Check out their website. They have many different designs to choose from in contrast cut of whatever. Also whatever faceplate design you choose they also have the same design for their wheels if you decided to get wheels eventually. Just a idea to look into.
