Just put iso grips on my 2014 RK. Only thing I would add is that before you loosen the brake and clutch assemblies put some tape (I used blue painters tape) around the handle bar as a reference so that when you put it back together you'll know how far in on the handle bars it was originally. I also put a mark in the tape to show where the two halfs of the clamp met. Hope that makes sense. Also as has been pointed out the brake switch can be a pain ,I had to take the assembly apart as the switch had unsnapped from the handle bar and switch housing.
