Pretty damn HOT!!
Old 06-25-2013 | 10:25 PM
rlawless's Avatar
rlawless
Default Pretty damn HOT!!
Getting ready to ride out of Phoenix to Denver. Going to be hot this weekend along the route. Plan to drink lots of water. I have a hydration vest to wear. Have any of you used one of this type vest, and how well did it work? Thanks for any feed back you provide.
Old 06-25-2013 | 10:37 PM
bobad24's Avatar
bobad24
I live in Phoenix and made a run up to Denver last August. I also have a hydration vest and it works great for about an hour. It will get you out of town and up to a little core elevation. They dry out pretty fast in this dry climate. I always leave town either early in the morning or later evening so I don't have to deal with the heat as much. What route are you planning to take?
Old 06-25-2013 | 10:41 PM
Waff's Avatar
Waff
Never had a vest but I can tell you it's getting hotter here in Colorado. No rain in the forcast.
Old 06-25-2013 | 11:18 PM
dan conner's Avatar
dan conner
the vest would work best with some type of mesh jacket. dries out quickly...but stays damp for a long time. have to hang it up in motel room at night or strap it on top of your other gear so it can dry out. to reactivate vest you need to soak it in cold water in a sink or something similiar. it gets you going in the morning, but not easy to use in the heat of the day when stopping for gas. a long sleeve tee shirt and drink lots of fluids and you will be fine.
Old 06-25-2013 | 11:49 PM
rbm33's Avatar
rbm33
i cant say that I have ever tried one on the street but I have used them extensively on offroad. they can be great to an extent, but if the humidity is very high the effectiveness of most cooling vests is pretty short and can actually turn dangerous if worn to long. in a high humid environment once the jacket warms up it basically turn your body into a radiator.
Old 06-25-2013 | 11:56 PM
soft 02's Avatar
soft 02
Get a Camel pack and fill it with Pedialyte. Hydration vests help. Make sure your skin is covered. Sun block of corse.
Old 06-26-2013 | 12:03 AM
ch54's Avatar
ch54
I used one for a stretch of the California desert during Run for the Wall. Wore it under a mesh jacket from Barstow to Needles. It helped, but it dried out pretty much by Needles. To be fair I didn't have an opportunity to soak it in Barstow, but I had soaked it before we left RC and carried it in a trash bag until I needed it. Didn't think I would need it anymore after that so I dropped it off with my daughter in Holbrook.
By the way, It's supposed to be 105° up here this weekend.
Old 06-26-2013 | 12:09 AM
Pelonz's Avatar
Pelonz
Get a large ziplock bag and re-hydrate your vest at fuel stops. They work best under a mesh jacket. Don't forget to hydrate yourself as well. I also wear a Chillipad http://www.froggtoggs.com/chilly-pad-9.html you can pick one up at Wallys
Old 06-26-2013 | 12:15 AM
soft 02's Avatar
soft 02
Stay away from coffee and soda. Both are diuretics and actually inhibits your body from absorbing water.
Old 06-26-2013 | 12:16 AM
bent trix's Avatar
bent trix
As the folks ahead of me said - The vest is helpful and lasts about an hour in the heat. In the past I have used a restaurant toilet tank while eating breakfast to re-soak.
I would suggest departing at 2 or 3AM if possible. The forecast for this weekend is 118+ in the metropolitan area.
Wear plenty of sunscreen on the exposed areas.
