How to bypass the rear amp
I have an 06 Ultra Screamin Eagle I want to put on a quick disconnect on tour pak which the amp sits under. I have read articles on here regarding putting them in your saddle bag etc. but that's not what I want to do. I want to get rid of the amp under the tour pak completely. I called Hogtunes and talked to them and he stated that if I will hook the speakers up directly to the radio you can get rid of the amp in the rear. Then purchase a four channel amp to put under the front fairing to replace it with just the standard installation. What wire's from radio will do this? Will you loose fade or intercom when done?
I thought I could put plugs on the intercom, rear radio volume control and speakers under the seat. Put hidden attenas under fairing with amp.
Am I just asking for trouble?
Thanks for the info. I just don't want to loose any of the functions, intercom and volume control on tour pak etc. I will start accumulating the things needed and make this my winter project. Quick disconnect for the tour pak, seat, amp and lower fairing speakers.
VINNIE JAMES
06-04-2009 08:10 PM
