sG Rear Turn Signal Question
Old 06-20-2013 | 09:57 PM
TexFF's Avatar
TexFF
Default sG Rear Turn Signal Question
I'm looking @ changing the rear turn signal bulbs in my '09 SG. I keep reading they are 1156's because they are only turn signals. Mine are running, turns & brake. I do have the large center brake as well. Did the PO change something that I'm not aware of? How can a 1156 be all 3? There's a part number on the bulb but it's like no other bulb # @ the auto parts store.
Old 06-20-2013 | 09:58 PM
jus2anoyu's Avatar
jus2anoyu
How many contacts does it have on the bottom? If it's 2, 1157 or 2057 will work.
Old 06-20-2013 | 10:09 PM
TexFF's Avatar
TexFF
Only 1.
Old 06-20-2013 | 10:12 PM
jus2anoyu's Avatar
jus2anoyu
If it has only one contact, it cannot be run, turn and brake. And that is a 1056/1156
Old 06-20-2013 | 10:17 PM
bberck's Avatar
bberck
Sounds like the PO installed a run/turn/brake module. Your bulbs woukd be single element.
Old 06-20-2013 | 10:21 PM
jus2anoyu's Avatar
jus2anoyu
Sounds useless to me. 1 contact means 1 filament, which means no difference in intensity?
Old 06-20-2013 | 10:27 PM
TexFF's Avatar
TexFF
I just checked again. It had 1 contact BUT it is a running lamp, then it gets brighter when I apply the brake and it gets brighter when I turn the turn signal on. How's this possible?????? I'm lost.
Old 06-20-2013 | 10:36 PM
TexFF's Avatar
TexFF
You must be right. I told my wife I must be going crazy. She said 'who cares!' Ha!!! Do you know where on the bike it would be located so I can figure out which one it is?
Old 06-20-2013 | 10:39 PM
acchd's Avatar
acchd
Look for module under your seat plugged into rear fender harness. Looks like this.
http://www.harley-davidson.com/store...11-6946106b--1
Old 06-20-2013 | 10:48 PM
TexFF's Avatar
TexFF
Thanks. I found it. Does this do anything for 'load equalizing' so I can add LED turns?
Quick Reply: sG Rear Turn Signal Question
