Battery charge
Battery charge
Before I installed my stereo and speakers, I keep my battery on trickle charge, and it stayed charged. After the install of my stereo, I put it on trickle charge and it never shows a green light, (full charge). It was a biketronices stereo, so no splicing, there wiring plugs into my wiring. And battery is new. Any opinions on this?
Lets see, the radio is using a harness that plugs into the stock harness, correct? If so, all power to the radio and amp (if you have one) should be cut when you turn your ignition off, right? The only thing that should be active all the time is your security system, if you have one......
Let us know the outcome...........
