Baffle questions
If it's louvered, see if the louvers 'catch' the exhaust if so, maybe you can invert the baffle so that the exhaust 'flows over' the louvers. That will make a difference. If the exhaust is already flowing over the louvers, you can flatten out several inches of the louver with a hammer and a dowel (be careful not to distort the baffle) and that will add some sound.
If you put more holes in the baffles, its gonna make more sound. If you cut the end off of the baffle you will increase the flow significantly, no restriction, no backpressure. Or you can hack the baffles and put torque cones in it, that will keep some backpressure. You can get em at the stealer for less than 30 bucks. The wild pigs you have should sound good already, how much louder do u want it, lol. Good luck.
