Best Neck Grease
You want a grease with a high temp rating. That stuff tends to ooozzzz out in hot weather on extended rides, then runs and drips all over stuff. Gets on your fender, the front of your bike, and sometimes makes you think you have a front fork leak.
I used Lucas Red n Tacky, but I am not satisfied with it because after a couple of years it starts that running mess too. I am sure others will chime in with their experiences.
That steering head neck/bearing area will take a lot of grease before it starts squirting out of the top and bottom. So just keep pumping!
I've been using Green Grease for several years with no leaking out issues.
http://www.greengrease.net/
