lowering Road King Custom (FLHRS)
Hey everyone,
I want to lower my Road King Custom. I know it is already lowered in the rear, but I would like to see what else I can do. Has anyone done this? What about lowering just the front end? I am not looking for anything radical, but I would like it a bit closer to the ground. I do ride 2 up sometimes so perhaps I am being a fool.
Thoughts?
Thoughts?
RE: lowering Road King Custom (FLHRS)
you say the bike is already lowered in the rear???? If the bike is stock in the rear you can NOT just lower the front.. You asked for other options?? I am a firefighter and we have a "Frequent flyer" (she falls down a lot and calls usto stand her back up)that has earned the nickname 480 Katie - put her on the back and go for a ride - bike will surly ride lower
I tried a search, but I must not know what I am doing.
I understand the pros/cons of lowering, but I guess I am asking what parts did you use to lower your bike? Where did you get them?
p.s. When I said it is lowered in the rear, I meant it is stock (the Custom is lower than the other Road Kings).
ORIGINAL: HDChloe
I installed the Touringkit on my RK Custom when Ichromed the front end. No handling problems and it lowered it about 1" on the front or about 1/2" at the seat. As far as the difference between the two kit it looks like for an extra $100you can convert it toair ride similar totheDressers.....I could be wrong though.
I lowered the front of mine with the HD Profile front lowering kit. I lowered the rear with So-Low lowering blocks (they do not change the shock angle so you use the Road King Custom saddlebags) combined with the Legend Air ride system. I used the lowering blocks so that when the Legend System is fully extendedthe rear sits at the same height as the stock Road King Custom rear and is compatible with the lowered front end. I also lowered the front fender to be closer to the tire. This restored the distance from the bottom of the trees to the top of the fender that was decreased when the front end was lowered.
[IMG]local://upfiles/21029/DA2CF56C012B43C3AD5C864458F80519.jpg[/IMG]
