I installed a Ness shift linkage, and now it's so stiff my heel/toe shift levers are not "bouncing" back. I expected a little stiffness, but there is no play at all at the joints. I almost have to use both hands to move anything at this point. I loosened it, and it seemed to sloppy at the joints
When I up or down shift I have to push the levers back or it won't shift to the next gear.
I have that same shifter. Been installed for almost a year with no issues on my UltraClassic. I cant see where the shifter linkage would be an issue. Is the year/model correct length wise? Maybe remove and put it back on again.
Never mind, I figured it out. Lesson learned, torque to specs.
I just put this part in my softail and halfway on a ride experienced the same problem that progressively got worse. What was the problem you found and the fix ?
I installed three times, but ended up throwing it in the parts pile.
I will never purchase an Arlen Ness accessory. Tried to call them before making a purchase (twice) and they never called me back. There are other better options out there...in my opinion.
