want to upgrade but not sure how far
Hello all.
I have a 2007 SG. I want to make some engine upgrades (cams, etc.) but i'm not really sure how far i want to go with it. I dont race my bike, get on it every now and then when riding with a couple of my crazier buddies but i dont ride with that group very often.
I am looking to have my bike pull stronger in my main riding area. 2500-4500 rpm. I have been reading posts for quite a while on cams and was nearly certain what i wanted to do and then i started reading about the FM 107 kit.
I like that if i get the kit i get a lot of new things with it (lifters and what not) that i would probably be replacing anyway with my bike starting to get up in mileage.
I would just like to hear some opinions from people on what might be best for me. I am
on a bit of a budget but when i do the build
i want to have everything i will want and
need. Dont want to have to keep tearing into it and adding stuff. Thanks in advance.
By the way. My bike is currently a stage 1 with a/c, pipes and power commander.
I will probably be in the minority opinion, but I leave my Harleys at stage 1.
this gives a mild power gain ( 7 to 10 HP generally), while retaining reliability, driveability and MPG
I got alot of friends with all built up bikes and they can be much less reliable, much less fun to ride in traffic or day to day...and the MPG seems to drop by as much as 25%
so maybe not great for a group ride as they have to time their stops differently...
then they get another bike and leave it "un-screwed with" for regular riding
Mike
Mike
Just wanted to add that when i mentioned up in miles i didnt realize i never posted the mileage. I am currently just over 60,000 miles. If i keep it at stage 1 what should i start looking into replacing? I have read about cam chain tensioners, lifters, and other things and just figured if i was going to get into all of that i would do some upgrading while i was at it.
There are many ways of upgrading your bike. The simplest IMHO is by getting a package from a well known tuning shop and FM is well known and liked here on HDF. We also have sponsor Hillside Cycle who can work wonders, no doubt others. As for tensioners, I believe your bike is a TC96, which doesn't have that problem, as it has a later better design.
I initially just did a cam upgrade (Andrews 37G) on my SG (TC88) and that was a worthwhile improvement. However, I just got my bike back last week from a 95" kit with headwork and SE throttle body. I haven't been able to really get into it, but it puts a big grin on my face every time I ride it. This is my second bike with fairly extensive motor work and I never had any reliability issues with the first, and hope to not have any with this one either. As far as rideability goes, the fun factor goes way up and it is not "twitchy" to ride in traffic.
I say go for the full monte with one provision. If you plan to keep that bike for a while, then do it. Don't dump a bunch of money into it this year, and trade it next year. That will sting.
Shakey
Shakey
For a good reliable budget build I would recommend have your cylinders bored for some SE 10-1 cast 103 pistons, Andrews 57h cam, Chev lifters, torrington cam bearings, new tensioners and have the heads checked plus a street port and ARCs. Ya should end up around 110 tq and 100 hp for under $2000 if ya do the work. If ya want more some forged 10.5 107" pistons and bigger cam with adjustable push rods would only be another $300 or so. After that I start thinking about crank work...
