Air shock leaking oil
Old 06-02-2013 | 02:24 PM
danny54's Avatar
danny54
Default Air shock leaking oil
My right air shock seems to be leaking oil. The bottom of it is dripping oil, I thought these don't have oil, Could it be something else? I have a 2011 ultra classic, Thanks for help.
Old 06-02-2013 | 02:27 PM
Juan L's Avatar
Juan L
Moderator
Yes they have oil, or at least one of yours did. There is no repair on these, easy and reasonable to replace. What length 12 or 13" because I have some take offs in my garage that are in great shape? I can ship both to you for 100 bux if you need the 13" ones.
Old 06-02-2013 | 02:39 PM
mrfuji's Avatar
mrfuji
Default air
check the air hose coupling blue-red most of the leaks come from there.pump air to max 30-50 .mix some water with soap ,put some i schock at the time.if leak you see some bubble.remove the air hose from coupling by pressing tab each side put hose back push only.rechek with max pression again.usely shock don t leak .if you loose oil this is because air pression are to low and you bottom them.mrfuji
ron1026
05-05-2016 06:09 AM
GEARMASHER
06-01-2015 09:45 PM
Bigdaddy_60
Air Suspensions
09-27-2013 07:54 AM
FL-kruzen
11-17-2011 08:10 PM
ricmd
06-07-2010 09:11 PM
Quick Reply: Air shock leaking oil
