2008 police seat on a 2011 ?
Old 05-29-2013 | 05:48 PM
scglide's Avatar
scglide
Default 2008 police seat on a 2011 ?
I have a chance to pick up a police solo seat off a 2008, does anyone know if it will fit on my 2011 ultra? Already did a search and couldn't find the info I need.
Thanks,
Steve
Old 05-29-2013 | 06:13 PM
glide2meetu's Avatar
glide2meetu
I believe they will be the same. In 2008 they changed the seat configuration so the seat has the hole in it vs a tongue. If not someone will chime in and correct me.
Old 05-29-2013 | 06:45 PM
08rking's Avatar
08rking
In 2009 the frame was redesigned on the touring bikes, so I would say probably not. You will want one that fits a 2009 up. That being said, I love my police seat and you should be able to pick up a complete unit for your bike off e-bay. I got mine a couple years ago for $150 for the complete setup. Good luck
Old 05-29-2013 | 08:50 PM
glide2meetu
I am going to disagree about the seat. I know they changed the frame and all in 09 but the seat change came about in 08.
https://www.hdforums.com/forum/touri...n-2011-sg.html
Old 05-29-2013 | 09:56 PM
motorsgt8's Avatar
motorsgt8
It will work. I just put the same set up from an 08 on my 12 limited. Mounted the air tank under the tour pack same as a police unit except had to bend the front mount tab down. Mounted the tank on the plate frame bolts only, and no issues with it being loose.
Old 05-30-2013 | 03:52 PM
mrfuji's Avatar
mrfuji
Default 2008
glide2meetu.you right about seat years. but police seat do not have tongue or funnel .they bolts to the frame next to gas tank.and on rear they have spring.or air bag.beleive 2013 are different.mrfuji
Old 05-31-2013 | 07:03 AM
grbrown's Avatar
grbrown
The parts microfiches on Ronnies HD website are a great source of info. Most parts for that seat assembly are 08 or earlier, the only 09-later specific parts being the frame cover and air cylinder, but motorsgt8 has addressed fitting that.
WallyWhite
07-10-2019 01:55 PM
TomWoodgeard
03-05-2018 07:24 AM
Candubrain
07-27-2015 03:49 PM
ericj205
03-06-2013 04:51 AM
wsthomas
01-09-2013 06:06 PM
Quick Reply: 2008 police seat on a 2011 ?
