Backed out of garage. Washed it like I've done 15-20 times. Have both fobs. Turns over good but won't fire. Lights, fuel pump, signals, etc. work.
Any quick ideas? Got to get on the road!!!
Check your crank sensor connector plug. I had the same problem once, after checking everything I could think of, I pulled the connector apart and water dripped out. Dried it out and the bike fired right up. Worth a check....
Wait a while I guess. Did you use a power washer? Might be as simple as the plug wires shorting out at the cylinder.
No power washer.
Checked fuses.
Checked plug wires/plugs.
I put a plastic back over everything under the seat when I wash bike. Everything there was dry.
Took switch housings apart and checked them.
I'll check it when I can find it. Owners manual doesn't show it. I'll have to look on line to see where it's at.
thanks
Do you know where the sensor is? Look at your oil filter, it's the wire next to it attached to the front of the engine. Follow the wire down under the bike and your see the black connector.
