HARD KHROME T-REX beware!!!!!!!!
Old 02-23-2007, 03:56 AM
DI75's Avatar
DI75
DI75 is offline
Default HARD KHROME T-REX beware!!!!!!!!
Have a set of Hard Khrome T-ReX pipes... They were great right up to the point where the right side chrome cover cracked in half at the bend....Called Hard Khrome and actually got a person who told me to find my reciept and they would warrant the pipes... Now after 10 messages and numerous e-mails they don't answer or return my calls nor do they answer my e-mails!! So if your in the market for some pipes I highly recommend against buyingthe T-REX true duals because like Draggin Baggers they do not stand behind their product. So will order some Rienharts and another lesson learned....
Old 02-23-2007, 05:01 AM
PhilM's Avatar
PhilM
PhilM is offline
Default RE: HARD KHROME T-REX beware!!!!!!!!
That blows!
I'm sure you know I'm not a duals kinda guy, but I did run across this yesterday (http://www.danddexhaust.com/news/200...troduces_d.htm), and since I am a D&D fan I thought these might be worth a look if you're in the market. One this ya know for sure is that if it comes from D&D, it'll be performance oriented!
Old 02-23-2007, 06:43 AM
apachethunder03's Avatar
apachethunder03
apachethunder03 is offline
D&D, is it a spinoff from Cobra pipes? I use to have some Cobra drag pipes that really sounded good. Nothing but good words to say about Cobra.
Old 02-23-2007, 10:26 AM
Branded's Avatar
Branded
Branded is offline
Do you suppose that the T in T Rex stands for, TONY !!!
Old 02-23-2007, 10:29 AM
Bagger_Dave's Avatar
Bagger_Dave
Bagger_Dave is offline
I guess they needed a clamp there to relieve that stress!!
Old 02-23-2007, 10:55 AM
tgaetto's Avatar
tgaetto
tgaetto is offline
Was the right floorboard spaced off enough? I bought a set of pipes and had to take them off the bike I got them from. The spacers that came with for the board seemed a little to thin. I know this might sound crazy but is it possible the board was vibrating against the pipe helping crack?
Old 02-23-2007, 12:04 PM
UltraKla$$ic's Avatar
UltraKla$$ic
UltraKla$$ic is offline
Good to know DI. Sorry it was at your expense though.
These manufacturers need to have a message sent to them as they handle business like they are untouchable.[:@]
Old 02-23-2007, 01:45 PM
rollover's Avatar
rollover
rollover is offline
Mine had cracked in the same place. When I called HK, they told me I needed to return them to the person I bought them from and the person I bought them from(ACM) told me I needed to deal with HK. Talk about a runaround. ACM then told me to return the pipes to them, at my expense, and that they would then forward them to HK who would have to look at them and make a determination as to if they would replace them all the while my bike would be sitting without pipes. Both companies customer service sucks.D&D for the win!!!!!
Old 02-23-2007, 01:49 PM
PhilM's Avatar
PhilM
PhilM is offline
ORIGINAL: apachethunder03
D&D is D&D and has been since the early 70's. www.danddexhaust.com
I've seen Cobra stuff on metrics, but don;t know much about them.
Old 02-23-2007, 01:57 PM
pavermanter's Avatar
pavermanter
pavermanter is offline
Thanks for the warning, that was going to be my next purchase.
Guess I will Keep reseachin a bit more.[:@]
Quick Reply: HARD KHROME T-REX beware!!!!!!!!
