Bad day at the dealership
Old 05-26-2013 | 11:02 AM
Harleydaddy's Avatar
Harleydaddy
Post the name of this incompetent dealership so the rest of us don't get burned!
Old 05-26-2013 | 11:53 AM
user 8373900's Avatar
user 8373900
Sounds like a punishment for doing your own cams and engine work, they didn't do the build did they?
Mark
Old 05-26-2013 | 12:49 PM
Lowcountry Joe's Avatar
Lowcountry Joe
With all the very close dynoed maps available today, created on someone elses nickle, why not use one of those and maintain control over your tune and especially who touches your bike?
It was fine before? Before or after the cam job? Did you install the cams/ pushrods?
Old 05-26-2013 | 12:58 PM
Retrop's Avatar
Retrop
Originally Posted by cuda67bnl
No way in hell the bike loses that much power from cold to hot, unless you break something........ Also no way in hell you're pulling mine off to work on another if you screwed it up.
Hell, I hate to add to this story because it is going down hill fast, but that is exactly what I was thinking when I read the story. I know I am probably in the minority here but there is no way in hell I would ever allow my motorcycle to be put to the abuse they go through for an hour or two on a dyno. I would just as soon take it to the burnout pit in Sturgis and smoke em till they blow. There is a reason they don't want you back there in the dyno room when they are flogging em.
Old 05-26-2013 | 01:16 PM
Lawdawg's Avatar
Lawdawg
Ft. Myers HD has a window and a lounge so you watch, there is also a computer monitor so you can see the progress.
Old 05-26-2013 | 03:02 PM
birdmandave's Avatar
birdmandave
Unhappy
Bike came with a SE Pro Tuner. Can find the cables but searched everywhere for software with no luck. Even my indy shop doesnt have it. Called the dealer and was told to bring it in to have it checked on the dyno. I'm scared.
Old 05-26-2013 | 03:34 PM
Harleypingman's Avatar
Harleypingman
Is this a bike you bought used?
Carl
Old 05-26-2013 | 04:57 PM
SG2011PAYNE's Avatar
SG2011PAYNE
no i just put se 204 cams se stage 1 air cleaner and had a canned map that had a bad hiccup at 1200 rpm other than that it ran decent
Mark
yes, se 204 and se tappered adjustable pushrods. did the install to specs of the manual
yes used and it only had 3100 miles on it
Carl
i am just wondering if there is a bad sensor. i had a similar issue with my pickup about 10 yrs ago
Old 05-26-2013 | 05:59 PM
Harleypingman
Ask if the bike is throwing any codes.
Carl
Old 05-26-2013 | 06:04 PM
slimvela's Avatar
slimvela
Buddy Stubbs cave creek Az...window so you can watch the magic happen.
Gods luck with that dealer, you're going to need it.
Quick Reply: Bad day at the dealership
