Help with hardbag bars
If you take them off, you have to remove the side rails on your saddlebags as well (looking at your signature photo). IMO it's easier and cheaper to modify the passenger footrests. There are options for moving the ones you have and/or adding extenders.
I'd be leery about having no saddlebag protection. But I understand it's your ride, not mine. Just saying.....
Good luck, and ride safe.
Here's the Rivco mount:
Rax
There's also the Kuryakyn Adjustable Foot Peg Kit that will give her several options as far as height is concerned ... While you're at it I's also recommend a change in the Dzus Fasteners that attach the bags to the bike ... Once the rails are removed and you have a mishap with the Dzus ( stock ) bag fasteners there is no "fail safe" to keep the bags from completely falling off the bike ... You can build your own ( not much more than a 5/16 clip nut and a 5/16 x 1 1/4 bolt and necessary washers .. a total of 4 ) or you could use the Brukus Set up ... Either way it's a wise investment and an added bit of security too.
