Agitator wheels on a pre-08. Can it be done?
When I bought my 21" fat spoke wheels for my 01 electra glide the suppliers pressed in bearings for a newer bike so it didn't fit my axel, called them and they sent me out new bearings but i wound up picking up a axel off a 08 and just using that instead. So yes it should work if you either change the bearings on the wheel or change your axel. That's for the front not sure about the rear.
The rear won't fit, without serious surgery. I haven't seen a post from anyone who has done it, except one who fabricated a swingarm. It also requires a wider rear fender, so not for the feint hearted. The stock rear tyre that fits it is wider than an 04 fender!
The front can be fitted, but needs some effort to get it right. There are threads on doing it.
If your heart is set on Agitators do the front only. Otherwise an 18x4.25 with a 150/70/18 is what you can put on your year bike. The fact that the Agitator rotors are a different size is neither good nor bad but the Brembo calipers off the newer bikes work much better. I just got a set for my 05 and I also run them on my Dyna. Other options for calipers are PM or HHI.
