Checked My Cam Tensioners......
Old 05-22-2013 | 06:55 PM
CSS_FXD's Avatar
CSS_FXD
Harley cruiser thanks man for the detailed info and advice!
Yeah bike is all buttoned up guys so no shoe changes from me on it. Bottom line is this just needed to make sure they were not all chewed up. I really was not going to put a few thousand into a bike I only like and not love and when I want a 2009 and newer but can't afford it. So I could of been stuck in a hard spot if they were toast. I can't dump money into a toy like $2k for a can update and the newer ones are too much at this time for wife and I. Looks like I will run the bike at least this year. Thanks all ride safe!!
  #42
Old 05-22-2013 | 08:24 PM
Harleycruiser's Avatar
Harleycruiser
Originally Posted by Leftcoaster
Real peace of mind comes with gear drive cams. You'll never ever think about cam chain tensioners again. That kind of peace of mind is worth every penny spent.
It should also be option number 5.
That we both agree with, wish I had gone gears at the first change.
Knowing that you have done this repair add tons to your opinion and advice, and that I respect.
I really believe the chunking comes from heat, all of them that I have removed and seen have had chunking, but I live in Florida, and it does get a little hot here.
Before I went to the hybrid kit I kept a pretty close eye on mine, I was getting sixty thousand from mine, and when I replaced them they still had a third wear to go.
Mine would start chunking at about fifteen thousand miles, and by sixty thousand, you could park a car in some of the pits, but like I said they still went sixty k.
One piece of advice for anyone, if you are running the original silent chains replace them every one hundred thousand miles as the chains get clogged with shoe material and they get stiff, causing the shoes to wear out from the jerking chain in ten fifteen k.
Mine did this and had replaced the shoes several times before i figured it out.
  #43
Old 05-22-2013 | 08:27 PM
Def Mute's Avatar
Def Mute
A little something for thought...
Those old tensioners failed because of the manufacturing process. During the molding of the plastic shoe, they developed bubbles inside. (That is the 'chunking' that Harleycruiser is speaking of.)
There was a thin solid outer surface layer which had no bubbles. Once this outer layer wore off, the bubbles became exposed. This led to less wear surface available for the chain(s) to ride on. When that solid outer layer has worn off, the tensioners tend to wear faster. Some faster than others, I guess depending on how much bubbling took place.
Anyway, you have yours back together now, so it won't matter much to you. I just thought I might mention this for anyone else who is hesitant to change them out when they have the opportunity...
  #44
Old 05-22-2013 | 08:40 PM
Harleycruiser
No problem, the important thing is that you did an inspection to know if you had an immediate problem.
You have heard all the opinions, bottom like is there is always a certain risk whenever you do or don't do a repair.
You weight the cost/time/risk and make a decision based on that.
See you on the road.
  #45
Old 05-23-2013 | 04:34 AM
CGLTD's Avatar
CGLTD
These were mine at 70K.
  #46
Old 05-23-2013 | 02:27 PM
CSS_FXD's Avatar
CSS_FXD
wow Christophgage! Thanks for the pics looks like you caught it right in time. Did you notice more chain noise and or lower oil pressure?
Is there any warning sign I should keep an eye and or ear out for?
  #47
Old 05-23-2013 | 04:38 PM
pit1600's Avatar
pit1600
mine were not really bad at 40 but i'm more than happy with my "expensive" 510G.
If you want, just change them but don't forget bearings...
  #48
Old 05-23-2013 | 04:55 PM
CGLTD's Avatar
CGLTD
Well I didn't hear a differance until I replaced the cams, pushrods and tensioners. Then it was quieter! I think over time it got slowly got louder, but didn't notice as much because it was gradual? Then one day I really did listen and thought I heard a little bit of extra noise in there and opened it up. I seem to have a knack for checking things "just in time". I recently replaced my stator and found the compensator but was finger loose!
  #49
Old 05-23-2013 | 06:03 PM
DAVENRINO's Avatar
DAVENRINO
I got nervous at 38K and did the hydraulic tensioner upgrade along with the Woods cams. Of course that led to the 97" BB kit and SE heads. After the upgrades I had enough power to slip the clutch @ higher gears/RPMs. That led to the Bandit clutch. My original inner tensioner was developing cracks. Anyway, many $ later it is all good.
  #50
Old 05-23-2013 | 06:08 PM
FL-kruzen's Avatar
FL-kruzen
Those show normal wear. The divots are just air pockets that got caught during manufacturing, normal. You got good tension ears for another 20k
Quick Reply: Checked My Cam Tensioners......
