Checked My Cam Tensioners......
Old 05-21-2013 | 07:58 PM
watercop's Avatar
watercop
I have a 2006 RKC. did the cam plate and pump upgrade along with a mile cam change(as long as we were in there) my inner shoe was a good 50% worn. I have used Mobil 1 v twin since new and had around 15K on the odometer at the time of the change
Old 05-21-2013 | 08:20 PM
oldhippie's Avatar
oldhippie
I liked Option 2, but Watercop's solution above looks good too.
The 07s and up are an improved design.
Old 05-21-2013 | 08:55 PM
Harleycruiser's Avatar
Harleycruiser
There is a huge difference between inspecting the tensioners and replacing them both time wise and money wise. Anyone who has replaced them knows there is no “while you are in there” scenario, you are just scratching the surface of this repair when you take off the cover.
Same for the cost.
This bike has thirty k, and it is good for at least another twenty, in all honesty that is the lifetime for most Harleys.
If it’s not broke don’t fix it.
Old 05-21-2013 | 10:03 PM
CSS_FXD's Avatar
CSS_FXD
Well the cover is already back on it so I wont be changing anything at this time. I like the idea of riding it another 10-20k miles if I even keep it that long as I only really ride about 3-4k a season here in MN. Thanks guys for the input.
Old 05-21-2013 | 11:55 PM
FatTony's Avatar
FatTony
Originally Posted by Major Thom
So what bikes have this issue and has it been fixed on any newer bikes?
If by fixed you mean made somewhat less crappy then 2007+
JTM65 (11-21-2022)
Old 05-22-2013 | 05:48 AM
Harleycruiser
That is wise. Everyone with a pre 07 should do an inspection at 25-30. Thanks for showing how easy it is.
Old 05-22-2013 | 05:57 AM
Assegai's Avatar
Assegai
Yeah, I'd change them now while you're in there. You've got the **** out of job getting to the point of inspection. If you do, on reassembly ensure that you have the timing marks aligned.
Old 05-22-2013 | 06:13 AM
RK Joy's Avatar
RK Joy
I wonder if the condition would have been the same with Dino oil over the same miles and use?
Old 05-22-2013 | 06:23 AM
Assegai's Avatar
Assegai
IMO wear is dependent on RPM. Sustained higher speeds (highway) should logically result in greater wear.
Old 05-22-2013 | 06:52 AM
Harleycruiser
When you have the cover off you are not "in there" you are just looking at it. To get "in there" is a major job.
This is like saying while you have the spark plugs out put in new piston rings.
Op did the right thing.
JTM65 (11-21-2022)
Quick Reply: Checked My Cam Tensioners......
