Customising the SE tail pipe?
Old 05-20-2013 | 02:29 AM
andreacro's Avatar
andreacro
Default Customising the SE tail pipe?
Hello from Croatia, Europe!
I ride a 2012 FLHX. I have put on it SE 4inch tail pipes. (takeoff from a CVO, got it for a bargain)
Problem is that these pipes make my bike sound like a 250ccm scooter, BUT i love how they look.
Are there any products on the market that i could use to change the inside of the tail pipe to fix the sound?
(I have a big shipyard in my neighbourhood and acces to their machines, so the machining is not a problem.)
THANX!!
Old 05-20-2013 | 06:48 AM
HDDOC's Avatar
HDDOC
Old 05-20-2013 | 12:52 PM
andreacro's Avatar
andreacro
Thats it?!! I just have to remove two welds and get some perforated sheetmetal?
Heh, i can do that myself!
Thank you so much for the idea!!! :-D
I love this forum!
Old 05-20-2013 | 01:20 PM
Pumba11's Avatar
Pumba11
Yep, that is the way to do it.
Old 05-20-2013 | 01:22 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
Way to go HD Doc!
Old 05-20-2013 | 03:06 PM
Eshaw301's Avatar
Eshaw301
Or just take the baffles out altogether. That's what I did and man o man does it sound sweet. Rumble is so deep it makes your bones tingle. You dont need to break the welds either. Just go around the flat part with a hammer and a chisel and punch along the corner bend inside until it completely separates. What you will be left with is a ring that is held on by the welds. But by that time the welds will be broken anyways. That's what I did and I skipped the fullsac and left the mesh inside.
Old 05-20-2013 | 03:34 PM
Pumba11's Avatar
Pumba11
It may sound good, but how is the performance? For a SG I would do the Fullsac.
Old 05-20-2013 | 04:25 PM
Eshaw301's Avatar
Eshaw301
Peforms great. I haven't had any issues whatsoever. For me I just couldn't see spending $400+ on some vance and hines or Rinehart or any other muffler that wouldn't fare much better than a gutted set of stock cvo mufflers that I got for less than $100. So I took the rest of the money and used it towards cams and that probably was one of the smartest upgrades I couldve done. I will admit...its loud but its a deep throaty loud not the raspy kind.
Old 05-21-2013 | 12:31 PM
pit1600's Avatar
pit1600
get rid of the cat and it will sound better. Lots of threads here on how removing cat
Old 05-21-2013 | 12:47 PM
mkguitar's Avatar
mkguitar
+1.
"attempts" at modifying mufflers can sometimes reduce flow velocity and volume.
a few riders here have been happy with the results using stock mufflers after the catalytic converter is removed.
of course local regulation may make this a problem
mike
Quick Reply: Customising the SE tail pipe?
