2008 Road King - 'new' front wheel from older FL - axle vs bearing question(s)
Hey gang,
[Also posted in Wheel/Tire/Brake tech forum, and searched with no luck]
I'm replacing my stock spoked front wheel on my 08 RKC with a wagon wheel from an older FL (the old black kind). I had hoped it would "bolt right up" but the old wheel needs a bigger axle. (From my research, I think 1" vs the 2008's 25mm.)
If the above is true (measurements), what is the best route: a 1" axle (with spacers if necessary(?)) to utilize bearings in old wheel --OR-- a 25mm bearing kit installed in the old wheel to match the 08 axle/spacers?
Thanks in advance for any answers/thoughts,
TJ
TJ
TJ, can you confirm what the older wheel is? 'Old kind' is kinda non-specific! Your bike has 25mm sealed ball races for wheel bearings. From around 2000 the wheels are similar, but with 1" bearings. You can buy a HD bearing kit, with bearings and internal spacer, to adapt your 'new' wheel. However if the older wheel you have has tapered roller bearings, you have problems! Clarify what you have and we can give you better info.
All you need to fit your bike is a 25mm bearing kit. Harley sells them for their range of custom wheels. They come with instructions and it is simplest to get that kit, as you need the correct internal spacer, to go between those bearings. The 1" bearings are wider, so I understand the spacer in your new wheel isn't long enough to use with 25mm bearings.
Thanks for that info. I'll get a bearing kit on its way soonest.
Any recommendations for doing it without a bearing puller? haha I hate taking stuff to a mechanic... (I kinda tried a block of wood and hammer...gave up in fear of breaking something)
Or what about taking bearings out of the stock wheel and putting them in the new(old) one?
loseranacummins
Wheels/Tires
14
12-03-2013 12:55 PM
