Fuel Tank Quick Disconnect
I have a 2007 RG. It has the quick disconnect on the bottom of the tank. After upgrading the stereo and running lines and etc, I put the tank back on and my quick disconnect won't reseat. I've tried putting new o-rings wth lube on the male side of the connector but when I put it back in I don't get that audible click and gas still seeps out.
Any suggestions other than buying a new fuel petcock from Harley (yes, i've read that from searching)? By the way anyone know a part number for that?
sorry don't know the part # for you but I think you are on the right track , had my motor rebuilt and after the tank had been on for a few years the disturbed while the dealer did the motor the quick connect would not reseal and the had to change the part in the tank and the connector also , mine did lock just not seal
You can get the correct part numbers by going to the parts section of Ronnies HD website, where you can look at microfiche of the parts book for your bike, courtesy of mtclassic's link.
Have you used the correct size of O ring? If not the slightest increase in diameter will make it difficult to get the two parts of the thing to seat. It is likely they are not mating fully, causing your leak.
Tanuki
05-16-2014 10:13 AM
