THINKING OF BUYING PCIII? NOTICE TO 06-07 READ THIS FIRST!
Gutman....Do we know for sure that long term failures are high. Another question I have SERT vs PCIII. If one or the other should fail on you out on the road somewhere, I know you can just unplug the PCIII and run on your ECM settings. Can you do this with the SERT also?
ORIGINAL: FLHT
ORIGINAL: gunrunner
Well your right about the dealers and the SERT, 400+ for a link to reprogram your own stock ECM. hookup cable not included.
And as for this being a Known issue? I never new it when I bought mine back in october, and niether did many others, heck till some of us figured out it was a power issue most everyone thought it was a map related problem. The true problem has only come to light in the past few days and is now documented in writing by Dynojets responce listed above.
ORIGINAL: Gutman
I don't understand half the people on this site. This has been a known problem in the industry, this is not breaking news. Whenever there is a post on this site PC vs. SERT everyone has their opinions and most are the SERT is too much and dealers are just out to steal your money. Now when everyone hears this they say "I will live with it?" If this problem was with the SERT and the MOCO said they were doing nothing about it, we would be on the 23rd page already. Like I have always said, you get what you pay for. The PowerCommander is not superior to the SERT, only less expensive and works OK. The long term affect is that it still uses consumer grade electronics (same as your kids PS3 or X-Box) and long term failures are high.
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
ORIGINAL: FLHT
I just sent an e-mail to Dynojet tech support with links to both threads
ORIGINAL: Branded
Maybe the Dynojet folks will stumble across this thread and attempt to find a remedy.
ORIGINAL: gunrunner
Thats a easy answer, NO WAY! Afterall a SERT is not even a tangable object, it's just a key that allows the stock ecm to be reprogramed. If your sert modified stock ecm fails you loose the SERT as well forever as it can only be used once on a ECM. So once you use it to enter your stock ECM it is married to that ECM and can never be used on another.
ORIGINAL: FLHT
ORIGINAL: ironhorse
Stupid me, I got a PC III and Draggin Baggers. Whats next for me?
IronHorse
IronHorse
I knew nothing about my '07 until I joined this site. I not only know a 'little' now, but I know some of the problems I might expect after I clock a few more miles on it.
Keep the good work up, there are a lot of us reading these sites with interest.
