Leaks when pumped
Leaks when pumped
Hi! I have FLHTCUI 01, yesterday i trying to increase the air pressure in the rear shocks to riding with a passenger, but i used not the correct pump (not no-loss air) and have oil leaks from the pump. I think it was about 5 ml oils may be less. From front fork the leaks was negligible. I pumped rear to 15-20 psi, front stayed zero. What should i do with oil level in now ? Thanks for advice!
Skydude...
You really need to stop shopping at the kindergarten!
Unheilig, I don't believe that is enough oil loss to worry over. When it comes time, or sooner if you wish, you can always change the oil and verify the correct level. You say the front 'stayed zero'? If you mean the air pressure is not building up, maybe check your air lines/connectors first. If they are good, then get a friend to help you pump the front up while you listen for air leaking? Keep us informed on what you find, even the comic relief above likes to believe they are interested in mechanical information!
