Rear speaker placement on tour pac
Hey guys, I hate to aoppear aprehensive, but I'm sitting hear waiting for my Hogs Tunes Ultra to arrive and am worried about the placement of the rear speaker pods. How critical is this? I'l sure hate to have holes all over the place in the tour pac. Any advice would be appreciated to help getting them in the correct place.
Thanks much,
David [sm=thanx.gif]
Thanks much,
RE: Rear speaker placement on tour pac
Glad you asked the question, I was going to post a like message today. I was thinking about tracing the speaker and using that as a template for placement. Anyone have any other suggestions? I'm going to install all four speakers and amp on my RG. I've never had the fairing off before, how long will this task take? Thanks
Steve
Steve
Hey Steve, here is a link to pulling the front fairing, there are only 7 screws holding the thing together. Looks like a pretty simple task. https://www.hdforums.com/m_384080/tm.htm
David
David
I took the rear pods and used that Sticky Tack stuff from Staples (like silly puddy) and used three small pieces to stick them where I wanted them. I then used a small sharp awl type thing to make small marks on the tour pack. I then removed the pods and drilled away. I did find it hard to get one bolt through on each side. To fix this I drilled from the tour pack, through the hole that I drilled in it and made a new hole (bigger one) in the pod. Was very intimidating, but after the first was installed it took the edge off.
