Homemade Fuel Tank Quick Disconnect
Old 05-09-2013 | 11:52 AM
DRated's Avatar
DRated
Default Homemade Fuel Tank Quick Disconnect
Since I have the tank off, I want it to be easier to get the tank off next time without dousing my floor, towels and bike with gas. I know Herko makes a product, but has anyone made a homemade quick disconnect for the tanks. I'm sure the disconnect has to be a certain PSI rating... what is our fuel tank pressure...58 psi? I want to try and make a setup myself. Thanks in advance.
Old 05-09-2013 | 01:47 PM
foxtrapper's Avatar
foxtrapper
Veteran: NavyVeteran: National Guard
Wonder about the gas can disconnects from the outboard boating world.
Old 05-09-2013 | 02:10 PM
Puttnutt24's Avatar
Puttnutt24
I know Motion pro make's a quick connect cross over line, check Ebay. I made my own as you see here, I can't remember where exactly I got the fitting but it was also on Ebay. Quality part and it sure does make removing the tank a snap
Old 05-09-2013 | 02:22 PM
RollaMo's Avatar
RollaMo
Your fuel tank itself is not under pressure.
You can prove that by taking the fuel cap off while its running, and it won't be under pressure.
For fuel injected bikes, the fuel pump is inside the tank and only from the pump to the fuel injectors is pressurized.
You should already have a quick disconnect on the fuel line coming from the tank.
If you have a crossover line to equalize the fuel level between sides, it does not need high pressure fittings since it isn't really under pressure.
Old 05-09-2013 | 03:23 PM
cjbmustang's Avatar
cjbmustang
i always thought throwing in a 3 way valve would be a nice feature...wouldn't really blend in though.
If you had some type of "T" you could attach another line to the bottom of it and open the valve for an easy way to drain the tank. I just pull the line an hope I don't spill too much
Old 05-09-2013 | 06:55 PM
DRated's Avatar
DRated
Thanks everyone for the replies. I'll be hitting a store for the fittings...
Old 05-10-2013 | 12:51 AM
Pelonz's Avatar
Pelonz
You can get fittings here http://www.coyote-gear.com/quickdisconnects.html
A search on the forum will give you a couple more.
OrdO8085
04-03-2022 03:08 PM
High Roller
03-14-2015 08:07 PM
brihvac
11-06-2010 10:28 PM
mulch63
05-11-2009 08:14 AM
cabentz
12-29-2006 10:26 PM
Quick Reply: Homemade Fuel Tank Quick Disconnect
