Road Glide Windshield Rattle (@ Idle)
RE: Road Glide Windshield Rattle (@ Idle)
Apologies for what may be a stupid question but how difficult is it to remove and swap windshields on the Road Glide? Is it simply a matter of unscrewing the 6 screws (or however many there are) at the base of the shield, lifting it out and dropping the new one in? Any potential "gotcha's" to look out for (for example, dropping a screw or washer down into the fairing)?
ORIGINAL: TowJam
It's a piece of cake!! Remove the five screws from the well nuts, take off shield and then put new one on. Make sure the well nuts stay in place and then work from the center back on both sides and then after you get all the screws started, snug them down from the center back. ***** Key Word SNUG ***** do not over tighten or you may damage the well nut and it can pop loose while riding. Ask me how I know!! LOL!!!
If you get the Clearview you will never need or want to change again so get that and only do it once.
I also own an 05 RG. I have had my bike back to the shop numerous times for vibrations for windshield and front end. The problem is two things. #1 the motor mounts need to be changed. Seems HD does not want to have a recall on this matter. #2 The setting for the front end Torque is set at 3, This was changed at 5,000 miles. This should be increased to 4 or 5. Theyincrease the front end torque atthe 10,000 mile check up to 4 or 5. I talked with thundercloud about this issue back in the summer. I checked myMotor Mounts and they were loose. Went to Hd and they changed Motor Mounts. Went back three more times, they changed windshield and did torque tightenning on front end. The problem went completely away. The windshields suck. I second Clearview shields.
Chuck
Chuck
I have an '02 RG and it develops a windshield rattle that turned out to be the inner fairing rattling against the outer fairing above the radio. Put some pressure on it there while it's rattling to see if it stops.I put a piece of foam between the radio and the inner fairing to stop it. As for the windshield mounting itself, I removed the outer fairing with the windshield still attached and drilled the windshield and fairing to accept another screw and wellnut between the outside ones on each sidefor a more secure mount. I had the windshield come out of the mounting on a very windy day at a fuel stop. 4 of the 5 screws go through slots in the windshield with only the center one being a round hole. I also installed a flat washer on the 2 outside wellnuts from the backbefore tightening them. The mounting holes in the fairing are oval and allow the wellnuts to pull through very easily. A 3/8 flat washer fits over the wellnut very well.
ORIGINAL: unclekunkle
Thanks for the feedback everybody. Last night a friend turned me on to a tube of "silicon paste"...this otta be more effective than the spray I used before. I'm gonna take it apart again, dress the rubber and see if that takes care of it. I appreciate the comments on "ClearView" though...cause I am considering a slightly taller shield next go-round.
Willl be taking my SG in for 10k service and hope that they will take my fairing/windshield rattle seriously. It's hard to isolate where it's coming from except there is a clatter in 1st gear from startup and at idle, mostly on the right side. Driving me CRAZY
Just one more thing to check when you split that fairing. Look closely at the outer fairing just below the windshield on the inside about where the sides of the radio mounting cradle intersect with the fairing. I had a previous rattle that was caused by interferencehere. I glued a piece of softer nylon webbing across the edges of the radio cradle to take up the slack where this was hitting. It's easy to spot as there will be 2 grooves wearing into the outer fairing with maybe a little white dust which is ground up fairing. There is a lot of flex in these fairings because of their bulk. I seem to have to "adjust" my fairing every 2or 3 years to compensate for something else colliding underthere! Part of the "ownership experience" I guess!
I used to notice a windshield rattle on my '06 RG, at the same time the fairing trim kept coming out betweeen the fairing front and rear. When the fairing trim gets fixed, I don't notice the windshieldrattling. But then, the fairing trim is coming out again ( for the 3rd GRRRR time ) so I'll try to pay attention and see if the windshield rattles.
For some beereason, I'm having trouble typing. I could either go ride my scooter in the rain and check for windshield rattle, or go to bed. What should I do ?
