New floating rotors now wheel tight
Old 05-08-2013 | 02:02 PM
casique's Avatar
casique
Check brake fluid level too to make sure its not too high...
Old 05-08-2013 | 02:27 PM
EasternSP's Avatar
EasternSP
Veteran: Marine Corp
Ride the bike a mile or so then stop and feel for heat on the plate then near the axel.
Old 05-08-2013 | 02:57 PM
VARDR's Avatar
VARDR
Brake fluid level has not changed, but will check. Will drive a few miles and check for heat. Thanks for the suggestions and comments.
Old 05-08-2013 | 03:05 PM
Sauceman's Avatar
Sauceman
Pull the calipers off and then spin the wheel. If it spins freely then it's a brake issue, if it still binds it's an axle/spacer issue.
cheers
Old 05-08-2013 | 03:26 PM
Lowcountry Joe's Avatar
Lowcountry Joe
cheers
Good suggestion to narrow it down.
If they over torqued the axle nut, then the bearings are seated to tightly against the inner spacer and they wont back out just because you take off the axle nut and re-torque to 65. If that is the case the races are already deformed and the wheel will be hard to turn with the calipers off.
Here's what you have in that front wheel:
The bearing with the orange grease seal is the abs bearing and installs on the left with that orange side to the inside.
As suggested, I would remove the two bolts from each caliper, remove the calipers and spin the wheel and see what happens. That will tell you which direction to go.
The dealer won't admit to any wrong on their end, so get use to that.
Old 05-08-2013 | 08:54 PM
sanman4ever's Avatar
sanman4ever
Originally Posted by VARDR
I called the dealer who installed the rotors and wheel and they said it could be my caliper pistons not retracting all the way...but they didn't offer to fix it.
Try cleaning the pistons:
http://www.motorcyclemetal.com/downl...rake%20Pad.pdf
http://www.lyndallbrakes.com/service-tech/
Old 05-14-2013 | 12:52 PM
clarkchriston's Avatar
clarkchriston
VARDR, I am having a similar problem that I posted about in aother thread....any word on if you figured out/fixed your issue.
roadkingbigjoe
05-15-2014 05:35 PM
clarkchriston
Wheels/Tires
06-19-2013 03:16 PM
weidna
04-06-2013 05:55 PM
gschwerman
03-26-2013 11:59 AM
rrk05
12-10-2009 06:43 AM
