Mobil 1 sale at Advance Auto
Advance Auto Parts has Mobil 1 on sale in their most recent flyer.
5 quarts plus a filter for $32.99 in store only.
No exclusions listed as to type so may be a great way to pick up some oil and filters.
I dont have one local to me otherwise I would be all over this.
http://shop.advanceautoparts.com/wcs...2013-flexi.pdf
Go into ANY Advance Auto and ask them if you can get 5 qts of 20w 50 M1 V Twin instead of the car oil and the answer will ALWAYS be the same. No. Many have tried (including me) in many different Advance stores and none to my knowledge have succeeded. The v twin oil simply costs more per qt (minimum $11.00/qt whereas the car ones are $8.99/qt). Where it says "no exclusions" means no exclusions in the standard Mobil 1 car oil variations (except the high mileage ones which again, cost more) I use Mobil 1 in all of my Jeeps and Harley's and regardless of the cost, is worth it, IMHO.
https://www.hdforums.com/forum/touri...50-v-twin.html
To the OP, thanks for the info - I need to change the oil on the Explorer.
Any automotive oil which doesn't have the "energy conserving" tag on its API starburst symbol also doesn't have friction modifiers and is therefore wet-clutch-safe.
I use Mobil 1 15W-50, which is effectively the same except when cold, when it's a little thinner (which is beneficial.) There is absolutely no need to spend the extra for the V-Twin oil over the automotive non-energy-conserving Mobil 1 15W-50.
The only significant thing that makes the "V-Twin" oil different from typical automotive oils is that it does not contain friction modifiers, making it safe for use with a wet clutch. So if you're filling one of the holes that doesn't have a clutch, then the v-twin formulation is a waste of money versus Mobil 1 of the same viscosity anyway.
Ed Zachary! I do the same. M1 15W-50 car oil in the engine, M1 20W-50 V-Twin in the primary and Redline w/ Shockproof in the tranny.
