Installed my 15.5" apes!
Took me a few hours over a 3 day period but I finally got them done. I originally bought some PYO MBBs in 14" but after researching and wondering how I would wire them, I went with 15.5" Vindikta bars which are 1.5" diameter. Joe is a standup guy to deal with the bars are GREAT! I also added J&M rokker XT speakers and 250 watt amp while it was apart. My only gripe is that with these thick bars, I can't push them any further forward and the console doesn't fit up against the fairing nice and tight. Luckily all my wiring worked after connecting everything which was a huge relief. They feel awesome with the Kury ISO grips to hold onto.
Tear down, wiring, and assembly wasn't bad. My soldering gun wasn't great so wiring took awhile along with fishing a string through the throttle side after the TBW was in there but I managed. Clutch and brakes weren't bad either, just time consuming. I took my time and stayed very organized so without further a do...here are pics.
Cut out this pesky plug
Staying organized
Bars mocked up
All done!
Staying organized
Bars mocked up
All done!
Sweet looking! Joe at Vindikta was great to work with on my bar purchase as well.
Curious, I noticed you said you can't push the bars up any further. Can you push the bars far enough forward so that the vertical tubes of the bars are perpendicular to the ground? Basically straight up and down?
This was something that I spoke to Joe about when he was doing my bar build. I had him add a few extra degrees in the bend where the vertical tubes and the base of the bars meet. It worked perfect for my bike and my bars can be pushed enough forward so that the vertical tubes are perpendicular to the ground. It was the look that I was going for.
Thanks Rich! I really like how they feel and they're way better than my Fatboys apes. Just gonna rock it like this until next deployment and I can get some nice wheels. I wanted to black it out like yours but I think the chrome and black stand out so good.
And yes the diameter made it ALOT easier to pull. I had these and the MBBs side by side and wasn't sure how it would work with the smaller ones.
Mine are vertical and that concerned me as well. Wished they were a bit more forward but I don't like this stock seat anyways so once I get it dialed in I'll be even more happy. I think if those uprights are inline with the forks it looks weird. If you see my sig pic I had my old apes WAY forward and probably more than that after the pic was taken.
