I got a P0108 code after cam swap
Finished a cam swap on my 05 Ultra today. Installed S&S 585 cams and went for a test ride. Ran great for about 7 miles then lost the throttle response and limped it home the last 1/2 mile. It has EFI but will not start unless you crack the throttle like a carb. Bike has 35000 miles on it, 103 ci with head work and a PCIII. From what I can find out a P0108 code is a high map sensor or the ECM. Any thoughts or ideas on where to start would be appreciated.
BBB
BBB
Just a few possibilities. A high MAP signal is normal usually when the throttle is at or near WOT. But I believe the ECM can detect a MAP reading that is inconsistent with the throttle position. So if there's not enough vacuum at the sensor location (engine side of the throttle plate) to match the partially closed throttle plate position it means something is wrong. There should be more of a vacuum with that throttle position. But there's not. Thus the high MAP signal error code. And limp mode. Causes could range from a throttle plate not operating properly, severe air leak, faulty sensor, throttle cable out of adjustment, an intake valve not opening (adjustable push rods?), plus other possibilities like a bad ECM, tune, etc.
edgeofinsanity
03-25-2012 02:56 PM
