Has Anyone Upgraded Rear Light Bar??
http://www.ebay.com/itm/Smoke-Tri-Ba...1db130&vxp=mtr
![](http://i.ebayimg.com/t/Smoke-Tri-Bar-Fender-LED-Tail-Brake-Signal-Light-for-Harley-Street-Glide-Touring-/00/s/NDgwWDY0MA==/$T2eC16RHJI!E9qSO8mt9BQCH(D7vj!~~60_3.JPG)
I have seen them from 40-80 price range and they are all the same thing basically just different sellers. These actually have yellow turn signals in them... dunno if I care for that part. May just get one and crack it open and check the quality of the led's and if not bright enough replace them with my own led's and epoxy it back up, Then I would make it just a big *** bright brake light tail light combo. and save the turns for the filler panel.
You have an ebay link, the ones I have found dont work on my 10 sg[/QUOTE]
I wanted to remove the stock rear light bar on my 2010 SG. Use a curved license plate to cover some of the holes. For turn signals/brake lights I was thinking about using plasma rods from Custom Dynamics.
Wanting to know if anyone has modified their bike and removed the rear light bar?
Any pics or input would be great. Just trying to change up the look on the rear fender a bit.
Thanks
Thanks
https://www.hdforums.com/forum/touri...2010-sg-3.html
Meanjean, go here and check. Timberland convinced me of a great led light to convert to. Much cheaper than CVO!!! I used a Yaffee Stealth plate holder also. Will do what you want. PM me if you have any questions. Take care! Joe
Meanjean, I'm not sure you're going to be able to hide the oval cutouts. If you'll check, you'll notice a slight curvature at the top of the filler panel, along with the lights also tapering to a point at the top and the bottom ends. I made plastic caps similar to the rubber plugs, painted the same color as the bike, and they really are not very noticeable. Just a thought for you. I also used the Harley Tribar upgrade light, which offers run and brake. I think you will be happy with the choice. If you have questions feel free to PM me. Take care, Joe
