Ok, stage one just ordered. Have to install...
I just orders V&H Power Duals, twin slashes, HD air intake, and a Power Vision.
Everything should be here in the next few days. This will be the largest thing I've ever installed on any bike one my own. I'll keep you posted on the project as well as to put some pictures up.
Good luck to me, I might need it.
cool take your time.
on the PD's the clamp on the cross-under pipe should be oriented so that there is no hanging excess threaded rod ( or grind it off after install)- if this hangs, it can gran a speed bump and pull the exhaust system off.
2.) check torque on the tranny end cover ( "trap door") bolts, and use blue locktite.
revised torque spec is 25 ft lbs.
3.) anti sieze paste on the o2 sensors
4.) greasy fingerprints can be burned into chrome- completely clean the pipes before starting the bike for the first time
enjoy
mike
enjoy
mike
If you don't already have one, I recommend you pick up a factory service manual from the dealer. Probably get through this install without it but it comes in handy for torque settings, etc. plus any other maintenance you do on the bike.
Looking forward to the pics and report on post-install performance!
