Sound not as loud
Sound not as loud
Quick rundown, on my Electra Glide, I have the Hogtunes speakers a total of 6, with 2 amps, one amp for the lower fairing speakers and the other for the front and rear speakers. The problems is when playing the normal FM radio I get all the volume I need sometimes to much, but when I switch to satellite radio the volume goes way down, to a poiint where you really can't hear it well running 65mph, and thoughts, suggestions, ideas would be appreciated.
so the input to the system from the satellite is lower ( you don't say what you are using)- check to see if the output level of the satellite unit can be raised ( the delphi XM units have line level out put settings in the menu), other wise you may need to put a line booster in the signal path.
mike
mike
