Floorboard brackets, yet again...
I just today raised my floorboards so high my outer primary is making contact with the stock brackets when I hit bumps in the road. I was thinking about either putting a couple washers between the frame and bracket or even washers to raise the engine under the front motor mount. Been a while since I messed with the motor mount so not sure how feasible that would be.
I considered the floorboard extensions but seems that will put me back in the same situation of scraping the bottom rear edge of the floorboard. Thoughts????
I live in the mountains and can't help but ride hard. I throw the Road King around like people ride sport bikes so need the clearance. Actually none of my friends can keep up with me and some even get pissed but I would just as soon run alone. I learned long ago that you can't become a better rider by not pushing the envelope. It is how I get my thrills.
I did a search and this is what i found...Hope it helps..
https://www.hdforums.com/forum/touri...-time-wtf.html
Gotta wonder if you would rather ride alone...Why do you ride with others you can dust?
Last edited by riteway; 05-02-2013 at 06:38 PM. Reason: Deleted original thoughts....
To answer your question I have one guy I ride with regularly, several times a week usually. He knows I will slow down in the straights and wait for him. When I rode dirt bikes like an animal with its tail on fire I rode alone so a non issue for me. Would just be nice to have someone around for not if but when I go down. Can't help it or get it out of my system or making excuses. It is what it is.
If you want to continue to ride aggressively I would consider a good true air ride in the rear with push button control. That way you can raise the bike on the fly to gain extra clearance.
for the engine you only have 3 options, Washers to push out the boards, extensions for the boards or lower the boards down some.
I live on a mountain myself and ride aggressively. I only have 2 friends that will ride with when I want to have some fun.The rest I don't trust enough.
This is just ideas mind you.
http://secure.cyclesmiths.com/banana...9chrome-2.aspx
JCleary
09-02-2010 07:49 PM
