it's a brand new bike - let the dealer worry about it under warantee. fwiw both my 2010 and 2012 brakes squeek. i'm letting the dealer worry about mine until the warantee is up, then lyndal pads go in
Did your dealer fix it? They told me they fixed mine, next day squealing again.
You need some disc brake anti-squeak lube between the pads and the pistons.
+1.
I swapped out my rear brake pads and didn't use the anti-squeek.
Squeeked really bad. Especially when the bike had slowed down to the point it was just about stopped.
Removed the pads, applied the anti-squeek like I should have at first, and re-installed. No more squeek
