120/70/21 rubbing fender. Can I use 110/60/21 safely to create room?
I have a 2013 road king, stock fender with a 21 inch wheel, mounted 120/70/21 and it rubs the back of the fender.
I do not want to drill my fender to create more room. Can I go with a different size tire, narrower and smaller to create more room safely?
I called my tire guy and he's going to look up some tire options for me. I don't know if 110/60/21 is even made, I am just throwing numbers out.
How did you guys who run in to fender rub cure this issue without drilling?
I would like to get about 5/8 clearance so I don't damage the fender with rocks scraping the inside as well.
Any advice?
Also: I know some tires and bikes do not get any fender rubbing, however I am, so if your fender doesn't rub, I understand it happens to be luck sometimes. Just looking for guys who have had the problem, not the 'mine doesn't rub' thanks!
Any advice?
You could fab up some fender risers. I haven't found anyone who makes them for bikes below 2014. Other then drilling you fender out that is the only way I know to get clearance. I don't think there is a tire that size, but I am not positive.
I drilled my fender out and was able to get 3/8 of an inch of clearance. I went with a drill bit size larger than 3/8 which was a 25/64.
Mario77746
09-30-2010 08:27 AM
