Stoplights - Neutral or Clutch?
#93
I normally put it in neutral throw down some street cones and a few flares, then I stand at the ready with my 9mm in case anyone tries to cross my barrier until the light turns green <insert extreme sarcasm>.
Is everyone really that paranoid and safety conscious at every light? Sheesh, I'm calling BS.
#95
There is only one right answer to this issue. The motor needs to be in first, with the rider set up for a proper escape.
I've seen a few posts to this thread questioning the possibility of making an escape. That bespeaks a glaring shortfall in training.
At a stop, whether you're behind another vehicle, or first in line, it's critical to angle your motorcycle. The idea is not to go in line with traffic to make your escape. It's to clear the encroaching vehicle's path of travel, by moving to either the left or right.
This can only be accomplished by considering the situation as it is developing at each stop. Your best escape route will vary based upon the road's design, and the way other vehicles are positioned. For example, I tend to usually set myself up for an escape to the left. This means I stop angled to the left, and far enough back so that - from that angle - I will not have to steer to get past the the corner of the vehicle in front of me (usually about 12 to 15 feet back. By taking this position, if I see a vehicle approaching that isn't going to stop, I don't need to outrun the vehicle, I need only move forward, and to the left out of its path. If it strikes the vehicle that was ahead of me, so be it.
Of course, things like barriers, vehicles to my left, or the on-coming lane on narrow roads, may make an escape route to the left undesirable or impossible. Then, the set-up is reversed, so the escape is to the right. I cover this in more detail in my booklet Motor Lessons. It's always free. If you'd like it, please e-mail me at:
motorlessons@hotmail.com
Anyone who doubts this level of concern is necessary at every stop is forgoing a chance at protecting themselves. Riding a motorcycle means you're on a vehicle that is not as visible, and offers less protection in the event off a collision, than a car. However, it is also has more maneuverability, and generally better acceleration and braking than a car. Unfortunately, those riders who do not take the time to obtain proper training, and then practice their skills, accept all of the negatives, but gain none of the positives.
Harris
Denver, CO
www.youtube.com/conedown
#96
Agreed, I can't understand what all that nonsense is about. But then I only have half a million miles or so under my belt.....
#97
Ive been rear ended, I can promise you there is not enough time to react and get out of the way in alotof instances. I do agree you should always be in first on the clutch and prepared to move but highly doubtful you will evade an accident. It happens quicker then you think.
#98
#99
Don't usally pick sides here, but your statement is ignorant.
#100
While not being one to pat myself on the back, I used to ride the Alligator Enduro the day after it was offically run with a nationally ranked 250cc MX rider. He could never keep up. That being said, I don't know how much "talent" I have but I like to think it's more than most. I've been on two wheels now for over forty years. I've "lay it down" a few times. Once to avoid being killed, twice because "you never no how fast you can go until you fall down" which was the way I was taught to ride at the age of six.
I'm glad you road endurance races, whoopty do. I've been racing since I was 5 yrs old on pavement and dirt. Plenty of seat time. NO ONE lays it down on purpose. Ill give you an ok enduro of mine and you won't be able to just lay it down... Not as easy as you think.
You avoided most the impact by a panic job which resulted in YOU wrecking. Proper steering, braking and riding techniques might have avoided you to wreck all together.
