Garage Door Opener
We recently moved. Our Harley garage door opener worked flawlessly at our previous house. This house has a Chamberlain Liftmaster garage door opener. When I connect the Harley receiver to the garage door opener, our key fobs for the garage door opener work fine, but the remotes in our vehicles will not work unless we are directly under the opener in the garage. They will not activate the opener from outside the garage door. Does anyone have the Harley receiver connected to a Chamberlain Liftmaster opener that can give me some ideas on how to fix this issue?
Thanks,
Tin Man
Thanks,
Tin Man
Thanks,
Tin Man
Thanks,
Tin Man
The Chamberlain/LiftMaster/Craftsman openers with the multi-function door switch (the one with temperature, indiglo, etc) draws too much power from the opener itself and causes the secondary opener (H-D) to not work. I ended up buying a regular Chamberlain wall switch on amazon for about $12 and that solved the problem.
mikebaby
mikebaby
Thanks for all who replied. I have new batteries in the remotes. The Chamberlain Liftmaster wall switch has a large open/close button, lock button, and light on/off button.
I disconnected the HD opener receiver from the Garage door opener and the remotes in the vehiclles still wouldn't work, the small key fob remotes have always worked. The HD receiver was pulled in directly above the garage door opener. I unplugged the HD receiver and the vehicle remotes seem to work fine. It appears that the HD receiver is interferring with the Chamberlain Liftmasters ability to receive the vehicle remotes signal.
Although I prefer to have the the HD receiver installed directly above the opener, I guess I will have to locate it elsewhere and hope it works.
Tin Man
Tin Man
I too am experiencing problems with the HD receiver and the Chamberlain Professional Garage door opener. My problem seems to be limited range...I can't get farther than 15 feet from the reciever and the signal from the transmitter won't open the door.
However...I just have the basic wall switch installed and NOT the fancy digital one, so that's not the issue.
I have had a couple of the Harley units and their receiver interfere with many of the regular garage door receivers.
I switched to one called flash to pass and it works perfect. It's also a lot easier to hook up.
Take a look here: http://www.f2ptechnologies.com/products/
I actually bought mine at a local Honda shop for about $100. Tons better.
