I thought I remember something about removing the front fender off a late model touring bike? Is there a trick or is it simply removing the 4 bolts that go from the inside out thru the fender into the lower legs.
A small thin screw driver to bend back the locking tabs that lock the four bolts is handy. Get new locking tabs to ensure the bolts do not back out. I know many say locktite will work but I myself would rather trust a positive lock like the tabs provide.
you do not have to take the wheel off to take the fender off. It makes it easier but it is not necessary. Bend the tabs back on the bolt retainers and take the bolts out one by one. Leave the two front bolts in but loose until the end, then take them out and gently squeeze the fender and lift it out. Done it alot of times. Putting the fender back on is just as easy.
