2013 SG Rear Fender Tip Light not working??
On page 7-35 of the shop manual it specifically states, Models intended for sale in Canada incorporate both a turn signal light bar and tail lamp, and include an additional jumper harness. The jumper harness connects the tail lamp to the facia lamp. It appears from the picture (figure 7-34) that the facia lamp is a circuit board module/lamp assembly located at the very bottom of the rear fender.
Don't know about bikes sold in Canada, but my 2009 Ultra rear fender tip light burned out, seems back in 2009 they saved a penny and did not seal the hole where wires went into the LED light and it filled with water and shorted out the light, the replacement light had a drop of sealant in the wire hole!!
I believe after 2010 all Street Glides imported into Canada had the lights disabled or removed. It is a Canadian DOT issue. There are many threads here on the topic and some on how to get the lights installed.
Here is one. https://www.hdforums.com/forum/touri...e-led-mod.html
Anyways, Thanks for the help. Much Appreciated.
Cheers
Mike
That would be "Illumination challenged" you have to be P.C. Or you could hurt the MOCO's feelings.
Its not HD fault anyway. It's my good ol' stupid CDN gov't passing useless bullshit laws that aren't goin to save any lives and are more than likely based off the principles and ideals of some retarded special interest group instead of the entire country.
