Fuel line quick disconnect fied
Received 2,858 Likes
[quote=StreetGliderRider;11208634]So, I swap out my tank from a 5 gal. to a 6 gal and after completion don't you know the chrome coupler was leaking. After a few choice words, I turn to one place thatIknow has the answer (no not the stealer) HD FORUM. There is a rubber o-ring inside the coupler that could dry up or get pinched while re-installing the fuel line if you try to get it from the stealer, they tell you it is not sold seperately and you have to buy a new coupler that requires you to remove the fuel pump and float assambly because of the line that connects the coupler to the pump for mucho denero $$$. One post mention that the oil drain plug o-ring is the same as the fuel line o-ring, BANG problem solved HD part #11105, it works trust me no more leak. That said I want to once again thank the professional people of this wonderful forum. [/quote
I have this same problem, started all by itself yesterday. Got the same info as you from the stealer, but I knew there had to be a better way, and I just happen to have that o-ring handy. Do you have any suggestions on how to remove the old one and replace the new one? I know about the vaseline trick to hold it in place.
say what!!!!!! I know they are both round, black and have a hole in the middle but what the hell are you talking about............this is a post about o-rings......
Here's a follow up to my last post. There's another thread ("Major Fuel Leak") which discusses this problem and in fact has drawings and photos of the check valve. There are 2 O-rings in the valve, a smaller one which holds the poppet in, and a larger one which makes the seal with the fuel line connector-the larger one is closest to the opening, and uses the same O-ring, that the MOCO uses for the drain plug (11273) , and yes, I did double check the dimensions and it and it has the same dimensions (ID .414", OD .558" and thickness .072".) as n8dc mentioned in his post. The entire job took 45 minutes, would have been shorter but I removed the damaged O-ring "backwards" sitting on an upside-down bucket with a flashlight, dental mirror, and automotive pick. Having learned my lesson, I installed the new o-ring lying on my back looking up at the valve, took about 5 minutes. I put a little petroleum jelly on the O-ring to smooth the placement a bit. Bike started right up, no leaking (yet). My only concern is that the o-ring is rubber, rather than viton or nitrile, but I suppose if rubber is good enough for the MOCO, it's good enough for me, at least for now. AND, I'm really glad I didn't have to open up the tank and replace the entire valve assembly. But, it IS EFFED up that the MOCO wants you to spend $45 and who knows how much in labor to fix what appears to be a relatively common and easily remedied problem. I wonder if a viton or nitrile o-ring might last longer than the stock rubber one..
