Mounting speakers on engine guard
Hey good people I have a question in regards to mounting Speakers on my engine guards. I DO NOT want to drill my hard saddlebags, so I was thinking about getting some empty headlight housing and mount speakers in those.I really dont want to use the speakers pods that they sell either.I am trying to keep my Road King as it came. If anyone has any good ideals on how I should go about this I will appreciate hearing from you. Thanks
The lowers are cool, but not the look i want for my bike. I've been thinking about picking up the harley speaker system with the controls and such, only thing is, i run apes, and do not want that stuff mounted to my bars. I'd like to mount the speakers to the crash bar, but then the issue of where to put the controls comes up... i suppos the wires can just be cut and lengthened? and also, does anyone have these speakers? are they good enough to be heard going down the road mounted down low like that... keeping in mind i don't run a windsheild or anything?
I originally had the shark audio system, with the speakers that clamped to the handle bars, I can say they sounded pretty good. I did a lot of investigating and if you want them on the engine guard what a lot of people do is get another set of peg clamps, then get another set of driving light cans. You mount those to your engine guard facing you, then install speakers into those. How you hide the wires is your personal preference, drill or not drill...
For tunes, I have an iPhone, I ordered a $3 chrome plastic case for it, and modified it to make it easier to remove. Basically I cut away a lot of what holds it in the case. To remove it now, I lightly pry one end with my thumb while lifting the phone from the top... It holds tight and can be removed without much trouble... Then I used professional carpet tape, 2-way tape that will stick to dirty concrete! I put about 4 strips on the back of the modified case and attached it to my console.
The nice think about the shark audio system is the amp has a remote control and an FM radio built into it. The remove has 4 buttons, volume +/-, power, and mode. I haven't found the FM radio to useful. I love the volume controls though....
The amp is under the side cover, and i purchased an iphone audio cable that plugs right into the bottom of the phone. It charges the phone, and connects to the amp inputs. The amp has a standard 3.5mm jack.
I never built the light can speakers, but I have seen them and they look cool..
Here is a pic of my console while i was installing it..
thanks, i'll have to look into the shark stuff then. the ones my dealer has i believe are hog tunes? The speakers are chrome lookin and appear to be maybe 4 inches i'd guess? and they have a wired control unit that is supposed to attach to the bars next to the grip, to be controlled with your thumb. The remote setup would be way, way better for what i'm wanting.
Heres the system I have... $100 new... I bought mine used worked great.. I thought the little amp would die on these 6" speakers, it actually rocks them!
