cover not closing right
Old 04-20-2013 | 07:35 PM
pk54's Avatar
pk54
Default cover not closing right
The right side saddle bag cover doesn't seem to lock as secure as it once did. I saw a friends cover open up on him one day so now I'm locking mine until I figure out what changed. When I go to snap the locking mechanism it just seems a little spongy. Doesn't have that solid snap to it any more. Any suggestions? Thanks.
Old 04-20-2013 | 07:40 PM
davidwruth's Avatar
davidwruth
Is anything caught in the latch mechanism or gasket maybe or material holding lid on
Old 04-20-2013 | 07:41 PM
ChromeDomeDWG's Avatar
ChromeDomeDWG
Had the same problem on my '12 SG... found the latch hardware inside the bag under the canvas flap missing in one and loose on the others... tightened up and got new hardware... snaps tight again.
Old 04-20-2013 | 07:45 PM
2black1s's Avatar
2black1s
Check the canvas flap (or strap, or retainer, or whatever you want to call it). Sometimes it can get folded such that it gets between the weatherstrip and the lower bag. When that happens it will act exactly as you describe. If it has been folded in there, there will be a sharp crease in the canvas that you can repair by removing the canvas and ironing it out.
Old 04-20-2013 | 07:51 PM
robvg's Avatar
robvg
Same problem years ago. A wise member suggested removing the 4 screws that hold the piece of material...the strap....that holds the lid to the bag. Flip that piece up side down and reinstall. Worked for me
Old 04-20-2013 | 08:21 PM
Joe12RK's Avatar
Joe12RK
that's what happens - ironing may help but it'll fold again...
just poke it in with your finger and it'll close fine
Old 04-20-2013 | 10:18 PM
RollaMo's Avatar
RollaMo
This happens quite a bit.
Old 04-20-2013 | 11:57 PM
2whlr4life's Avatar
2whlr4life
Arrow
Check the spring underneth the latch/cover plate. One of mine broke (rusted, I think), and caused a similar problem. You can compare it's positioning to your other bags spring. That spring has its own part number, and is replacable with a little effort. Check all the nuts & bolts for tightness (which you've already done).
Old 04-21-2013 | 12:01 AM
Iceman24's Avatar
Iceman24
They loosen-up over time. Took mine off & switched w/new edge-cut latches...now they twist/lock shut like new again.
Old 04-21-2013 | 12:30 AM
DannyZ71's Avatar
DannyZ71
Bingo. This is more than likely the problem you're having. It is very common. I usually just get the lid in place, then run my hand under it to push the "tether" toward the interior of the bag, then lower the lid and latch it.
Of course the easiest solution of all, lock them when you shut them.
