Where to tap into for an oil pressure gauge?
Old 04-20-2013 | 12:54 AM
TUCCI's Avatar
TUCCI
Default Where to tap into for an oil pressure gauge?
Aside from the factory oil pressure switch where can I tap a line for an oil pressure gauge?
Old 04-20-2013 | 12:57 AM
soft 02's Avatar
soft 02
One of the two threaded plugs by the oil filter. But thats on a softail. Second thoughts on that gauge?
Old 04-20-2013 | 01:08 AM
Harleypingman's Avatar
Harleypingman
What bike are you doing this on?
Carl
Old 04-20-2013 | 02:00 AM
fabrik8r's Avatar
fabrik8r
Instead of tapping the oil system to put in another sender for a gauge, what about tapping the signal form the OEM sender and finding a gauge compatible. I don't think HD senders are particularly exotic, they are likely to have common electrical characteristics for that type of instrument.
Old 04-20-2013 | 09:10 AM
$tonecold's Avatar
$tonecold
Tucci, why don't you come by the house and let me help you with this before you do something that you might regret? I think you have my phone number in a PM I sent 3-19.
Old 04-20-2013 | 05:58 PM
2kids3pets's Avatar
2kids3pets
Still having a problem getting it off?
Old 04-20-2013 | 06:23 PM
TUCCI's Avatar
TUCCI
Got it off just fine but the AN fitting with the kit seeps oil no matter how tight I get it. Going to bypass the silver adapter that came with it with a 90° 1/4" elbow with a hose barb and thought I'd see if there's another place if any, I could tap into. Shame, had it all working just fine but couldn't get it to stop seeping. I'll get it figured out.....
Old 04-20-2013 | 06:26 PM
soft 02's Avatar
soft 02
Did you use any teflon tape?
Old 04-20-2013 | 08:08 PM
Tom84FXST's Avatar
Tom84FXST
http://www.mechanicsupport.com/articleFittingLeak.html
Old 04-20-2013 | 08:17 PM
$tonecold's Avatar
$tonecold
Tucci I would install the gauge where it goes without the line hooked up, then go for a ride. My thoughts are that this gauge isn't going to be readily readable in the position it is in and may well not be conducive riding comfort. When I was riding today I looked to see if a gauge in that position would be easy to read and my opinion is no.
Quick Reply: Where to tap into for an oil pressure gauge?
