Noise from Primary
Noise from Primary
I have an '11 SG w/ a 103" motor w/ low miles. When I feather the clutch to inch forward at a stop light and pull the clutch in quickly, I get a single slap noise from the primary. It does not happen when I simply pull the clutch and let it out in neutral. Only if I engage it and then pull it in quickly. It started all of a sudden. I'm thinking primary chain tensioner. It shifts fine. Anybody have any insight to confirm or refute what I'm thinking? BTW, I'm running Redline Primary Oil.
I think you should be able to replicate that noise stopped in gear at will. Just let the clutch out a bit and pull in a few times without moving. Not sure what the noise is but mine does it too. I took it to harley when I got my bike in 09 and the guy said its normal (standard answer Idk) but I have had my inner primary off and replaced with chrome and didn't notice anything unusual and that was 15k miles later. Have had the other side off several times too when I changed clutch cable to braided lines. No issues either. Have about 19k on now and everything still looks good.
It could also be the compensator. It is loaded when you let the clutch out some and the compensator sprocket has moved in the loaded clockwise position then when you pull the clutch the load is released all the way and it will snap back in the unloaded direction and makes the clank you are hearing. You have an automatic chain tensioner and it also could be ready to take up slack and let the chain slap the case. I doubt this is the case as it would leave a marks.
You have the SE compensator, I installed one on my 08. The only time I got noise was when I tried ATF in the primary. My theory is it was too thin. How does the Redline viscosity compare to both ATF and 20-50 engine oil? My primary is relatively noise free with 20-50 in it. The clutch was more prone to "stick together" with 20-50 or 20-60 so I now am running Motul 10-60 and am getting the better of the 2 options. The primary is reasonably quiet and the clutch is not as prone to stick together as with any of the 20- oils.
Just one guy's experience with one machine.
05HARLEYMAN
09-29-2006 06:22 PM
